Originally Posted by kach22i
Knowing where the airbag sensors and wiring are on your particular car will be a must.
The airbag sensors have not been mounted in the spoiler for years ...
Good point, perhaps next step would be an attempt to incorporate air curtains into the existing bodywork using similar principals
Most of the manufacturers use the material from which the spoiler is made as the outer edge and apply only a U-shaped air guide inside.
