Old 12-24-2020, 12:35 PM   #69 (permalink)
Vman455
Moderator
Vman455's Avatar
Pope Pious the Prius - '13 Toyota Prius Two
90 day: 51.62 mpg (US)
Tycho the Truck - '91 Toyota Pickup DLX 4WD
90 day: 22.22 mpg (US)
Air at the surface is motionless, held in place by atmospheric pressure. Air an infinitesimal distance away has a resultant vector that starts out normal and varies toward tangential, becoming tangential at the extreme.
I don't think this is correct; all the fluid dynamics texts I've read attribute the "no-slip" condition to intermolecular forces between the body and fluid, not atmospheric pressure.
When a fluid flow is bounded by a solid surface, molecular interactions cause the fluid in contact with the surface to seek momentum and energy equilibrium with that surface.
(White, Frank M. Fluid Mechanics, 8th ed. [Chennai: McGraw Hill Education, 2017], 32).
UIUC Aerospace Engineering
www.amateuraerodynamics.com
The Following User Says Thank You to Vman455 For This Useful Post:
freebeard (12-24-2020)
