Old 12-25-2020, 10:39 AM   #59 (permalink)
Piotrsko
Known issue on the fuel tank is either the inlet screen fell off, or got plugged. There's a mod called harpooning where you add a quick install nylon fitting in the bottom of the tank that stops the 1/4 minimum and reduces the #8 cylinder Injecting an air fuel mix AKA called "cackle". Crud in the bottom of the fuel bowl means nobody changed the fuel filter or used very dirty fuel. I've never had THAT issue. Heck, I never had the water in fuel light come on.
