Old 12-27-2020, 02:27 PM   #6 (permalink)
JulianEdgar
Finally summer in the southern hemisphere, so we get some more hard data posts from Julian!
Approximately what does this add up to in Cd? Any chance of a coast down test?
I've been doing a lot of aero testing over the last 6 months, so posting quite a lot of hard data.
I am confident that amateurs doing coastdown testing, unless perhaps done only between two very high speeds, does not give valid results.
Refer to SAE papers 950626 - ABCD –An Improved Coast Down Test and Analysis Method and 940420 - A Detailed Drag Study Using the Coastdown Method to see the level of complexity required to get valid coastdown results.
Or just do a series of tests, windows up / windows down in both directions - you should of course see a marked increase in drag with the windows down. I have never been able to detect this via coastdowns. On the other hand, throttle-stop testing sees this change every time.
The throttle-stop testing showed a change in drag with the air curtains of about 5 per cent. I never work from those figure to a proposed change in Cd, as I think such an extrapolation is too unreliable.
