Old 12-29-2020, 01:53 PM   #14 (permalink)
aerohead
drag
Originally Posted by JulianEdgar View Post
Yes, very interesting - and thanks for reminding me.
But if we look at the angle of that rear bumper taper, and do a forward force triangle diagram from that increase in pressure, it has to be really tiny ie the taper wouldn't be more than about 10 degrees, would it?
But I can certainly see a change in pressure there having an influence on the wake pattern.
I posted my video to Linkedin, and I have some contacts there who are professional aero people - both CFD and wind tunnel. I've asked if they have any ideas about the relationship between side pressures / degree of attachment and resulting drag.
I just always took it on face value that 'improved side flow attachment = lower drag' but like all aspects of car aero, the more you think about it, the less you realise you know.
1) If flow attachment can be maintained for the entire length of the body, on a body of progressive cross-sectional contraction, by default, the pressure existing at the separation line will be the highest achievable, translating to highest base pressure ( for that length ), lower pressure drag, and lower overall drag.
2) Minimizing separation is the drag reduction.
3) Un-rounding the curvature, but maintaining a streamlined profile, provided a little extra pressure recovery on the sides, with a drag reduction reward.
