A Jeep Cherokee with the 4.0 would be a great option!
If you keep the tires around stock size you could probably get 25-26 mpg highway with a little bit of work. I can get 22-23 with my heavy steel wheels and 31" tires.
I don't have any experience towing with it but I think it is rated for 5000 lbs.
Edit: You will be hard pressed to find an SUV that can tow 7000 lbs. It will be huge and get terrible mpg. I would recommend something with a diesel if you are open to it.
