Old 12-29-2020, 05:43 PM   #23 (permalink)
aerohead
constant throttle
Originally Posted by JulianEdgar View Post
Ok, you definitely haven't read how throttle stop testing works.
The engine is at a constant throttle. RPM varies inconsequentially The air/fuel ratio is constant. Ignition timing varies inconsequentially.
But look, don't worry about it. The technique works brilliantly - if you can't get your head around it, that's OK.
1) If you've altered the drag you've altered the road load horsepower requirement of the vehicle.
2) If the engine is not kept at a constant load, its BSFC will wander to a less efficient 'topographical region' of the engine's 'map.'
3 It doesn't matter if the throttle position, RPM, and stochiometric ratio are constant, you've altered the thermodynamic properties of the engine and they haven't been accounted for.
