Old 12-29-2020, 06:08 PM   #24 (permalink)
JulianEdgar
1) If you've altered the drag you've altered the road load horsepower requirement of the vehicle.
2) If the engine is not kept at a constant load, its BSFC will wander to a less efficient 'topographical region' of the engine's 'map.'
3 It doesn't matter if the throttle position, RPM, and stochiometric ratio are constant, you've altered the thermodynamic properties of the engine and they haven't been accounted for.
All right, it's obvious you don't know much about engines. For example, for a given engine and fuel, the stoichiometric ratio is a constant! (I think you mean air/fuel ratio.)
Don't worry about it. Maybe try doing some mapping of an engine from scratch, have your own chassis dyno, your own wideband air/fuel ratio meter, etc, etc, and then come back to me.
You know, experience and testing versus just theory (yet again!).
