Old 12-31-2020, 03:05 PM   #19 (permalink)
GrnFajita
I need to get better...
GrnFajita - '93 Ford Festiva L
90 day: 41.79 mpg (US)
Some mods driven by circumstances and coincidence...
In January my son totaled our 2007 Focus ZX5 which had a new set of tires, so I was able to keep the tires & rims when they hauled it off for scrap.
The next car in the fleet behind was a 1999 Escort that benefited with an upgrade from 185/65-15 to 205/60-16 larger diameter wheel package; more frontal area, but RPM ranges stayed closer to peak torque.
Coincidentally, bolt-circle adapters required helped provide a much smoother side surface at the wheel-wells (plus smoother wheels).
Also, coincidentally, new lower ball-joints were due, so I was able to adjust the installation to keep the ride height lower.
Ignoring the odometer and calculating point-to-point of my commute showed a 10.5% improvement, netting one more day between fill-ups, which was easily noticeable.
An air-dam and belly-pans are on the list for Spring.
