I figure this is gonna be a case of trial and error. I wish a tuner could guide me toward what I’m after but most of them are biased against the P11 PCM for some reason, and that’s the only other PCM that natively runs the first gen L61 in the US. My next engine is still gonna be a first gen L61, but modified a bit for higher volumetric efficiency. I need a different PCM because the planned engine is going to require a higher rev limit to extract all of its power potential and with a tunable PCM I could manage stuff like lean burn as well as the other stuff needed to fully utilize the engine
My current Ecotec project...
![](http://ecomodder.com/forum/fe-graphs/sig10025a.png)
My last Ecotec project...
