Old 01-01-2021, 04:50 PM   #11 (permalink)
toc
Sonata97 - '97 Hyundai Sonata GL
90 day: 25.96 mpg (US)
Pulsar - '03 Nissan Pulsar ST
90 day: 36.09 mpg (US)
Lancer - '04 Mitsubishi Lancer
90 day: 31.11 mpg (US)
Lancer 2.0 - '09 Mitsubishi Lancer
90 day: 27.1 mpg (US)
Originally Posted by 19bonestock88 View Post
Yeah I was figuring to just add a second coolant temp sensor that way each PCM got solid data. Given that the crank signal and VSS are just a pulse, would it even matter that the signal was split between two PCMs?
It wouldn't matter that the signal was shared - just has to be shared correctly.
It'd be wise to get the wiring diagrams for each PCM (I found mine on Google).
Check those and confirm the intended circuit each PCM requires..
I'm thinking along the lines of same operating voltages, and then ensuring the PCMs are of sufficient high resistance in the closed circuit state to not draw too much current.
