Tire size
I am running the stock LT245-75r-16 tires (80psi), if that will help your calculations. These factory Bridgestones drive quite well and are very likely going to be replaced with the same when the time comes ( we've got about 47,000 miles on the van now). I upgraded the shocks to Ridetechs... the factory shocks were nearly useless when the van is loaded.
I am not sure what axle is has, but as I said before the drivetrain on this van is much bigger than that on my 2002 Ford e250 with the 5.4 gas v-8.
