Originally Posted by cRiPpLe_rOoStEr
When it comes to acrylic/plexiglass, I have already seen some pieces thicker than an equivalent made out of conventional glass.
I haven’t yet determined the proper thickness but I wanted the pieces to be a direct replacement for the glass in the window regulators. They should still roll up and down like the originals. I’ll probably even apply tint film to them so that they match and look normal
I guess you're also going to remove the airbag sensors and other hardware, not only the dashboard and steering wheel mounted assemblies.
I’m gonna start by only removing the airbag assemblies, given that I don’t know exactly where all the sensors are. Probably will paint over the airbag light in the cluster so it doesn’t annoy me
