If you go to 13" wheels, for whatever reason, you'll find the ones with the same diameter as your 12's are hard to find (that's what the ones I mentioned having are), and if you go for the 155/80r13's of the later models, your speedo will be out...but you can switch the speedo gear to correct it. Will give you slightly taller gearing, though I'd assume the 13's weigh more than 12's, so the gains might be a wash.
