Originally Posted by Megdriver024
Basically like the 1.4 Multiair engine minus the multiair system..
So it's basically the same engine fitted to a similar version in my country, yet it was the 150hp version. IIRC the 120hp version was also fitted to CNG-capable versions of the Doblò and the Bravo in Italy and Germany.
It, has the same 16v head as other non turbo FIRE 16v engines.
The only application for the 16-valve 1.4 without a turbo in Brazil was the 500 while it was still sourced from Poland instead of Mexico and switched to the 8-valve.
