Wikipedia says 3,760 mm (148.0 in), same as the XFi. The slant-back Dasher can't compare with the VW Squareback.
Do you have further plans?
Well for efficiency there is a piggyback device witch can alter spark timing on LPG since it burns differently to gasoline. That could shave a whole L/100km from the consumption on gas.
I am still a bit afraid as it is a high strung little turbo engine, so it is easy to melt a piston or two
if things do not work out as intended + mine is remapped for more power..
Another area I will look into the summer is weight.. But I could use some advice on that..
