Old 09-28-2008, 03:05 PM   #19 (permalink)
ptsmith24
ptsmith24's Avatar
El Camrino - '90 Toyota Camry LE
90 day: 32.47 mpg (US)
Originally Posted by GeoGreg View Post
Hey how would you hook up the iduino mpguino straight to the battery? I was just wondering do you just attach a cable from the positive end of the battery to the 12v on the mpguino and then the negative to the ground or how would you do it?
I used ECU battery and ECU ground. Check your pinouts to see if that's feasible. Keep in mind you must use constant power (that doesn't die when you key off). That way it can keep your tank data. You can also find a wiring diagram for your radio. Radios generally have a constant-on power lead in order to keep station presets, etc. Hope that helps.
"It is foolish and wrong to mourn the men who died. Rather we should thank God that such men lived."
- General George S. Patton, Jr
