Old 01-08-2021, 01:31 AM   #601 (permalink)
Bicycle Bob
Bicycle Bob's Avatar
Last 3: 42.35 mpg (US)
It's got 40/60 weight distribution so I'm thinking yes. And with the cutaway wide body there may be an air curtain effect above them.
5mm aluminum belly pan. The exhaust is wrapped and the diffuser has a gold leaf finish to reflect the heat!
If it is tail-heavy, it would need fins at the back, not the front. However, off-road, things get ballistic, not air-borne when you need that much wheel travel.
The Following User Says Thank You to Bicycle Bob For This Useful Post:
freebeard (01-08-2021)
