Old 01-08-2021, 10:38 AM   #1049 (permalink)
hayden55
Sport Utility Prius - '10 Toyota Prius II
90 day: 52.98 mpg (US)
300k Sequoia 4WD - '01 Toyota Sequoia Limited 4wd
90 day: 20.19 mpg (US)
I need to spend 20 minutes backing up in a parking lot with a trailer using the rearview camera. All my life I've been looking over my shoulder, and knowing how to steer comes instinctually. Using the video camera is not instinctual for me even though the process is the same.
When the sides are off my Harbor Freight trailer, often I'm unable to see it looking over my shoulder, so I have to use the backup camera. I have a somewhat dangerous technique in the truck (no backup camera) where I sit on the window sill with a toe on the brake pedal while I hang out the window to view the trailer that hides behind the truck bed.
If you're talking about the Prius I pretty much always pop the hatch up and then back up. You can see everything when you do that. So much better rear visibility than a pickup.
"I feel like the bad decisions come into play when you trade too much of your time for money paying for things you can't really afford."
