Old 01-08-2021, 03:39 PM   #132 (permalink)
Vman455
Moderator
Vman455's Avatar
Pope Pious the Prius - '13 Toyota Prius Two
90 day: 51.62 mpg (US)
Tycho the Truck - '91 Toyota Pickup DLX 4WD
90 day: 22.22 mpg (US)
1) Yep, Hucho's a real slacker. His PhD in mechanical engineering, running a climatic wind tunnel for a decade, spending decades around automotive aerodynamics, and working under some of the folks who literally wrote the books on aerodynamics obviously would have no credibility when recommending a pathway to low drag.
I've mentioned this before here, but when I emailed Hucho directly last year and asked him what he would recommend to reduce the drag of my car, he said nothing about any sort of template, tapered tail, half-body of revolution, or extension at all.
Be sure you're differentiating between what Hucho has actually recommended, and what you recommend as pathways to low drag. He is by far not the only author to treat low-drag idealized shapes--although some others do at much more length--but all of them that I have read consider streamlined half-bodies as shapes which can be, in Hucho's words, "progressively transformed into a car." (He wrote this in a section which does not appear in the 2nd edition).
UIUC Aerospace Engineering
www.amateuraerodynamics.com
The Following 2 Users Say Thank You to Vman455 For This Useful Post:
aerohead (01-08-2021), AeroMcAeroFace (01-09-2021)
