Old 01-09-2021, 04:32 PM   #5 (permalink)
cRiPpLe_rOoStEr
Originally Posted by 67-ls1 View Post
I have a 2013 LFX V6 out of a Camaro. 3.6L (217 ci) direct injected with 4 variable overhead cams. It’s rated 325 HP and connected to a 6 speed double OD auto trans. Rear end is 3.07 ratio with 26.5” tall tires. RPM at 70 mph is just under 1700 rpm.
Makes me wonder to which extent the aluminium-block engine, also shorter than the old-school engines originally available when the Chevelle was new, might have affected the handling too. BTW was the transmission also sourced from the Camaro?
