Biased for right turns then. If you decide to build your own, go with the full length roof and give it some taper in plan (for the high speed aerodynamics.  )
Sure I would do a lot of things different than this one. Most likely resorting to a water-cooled engine, in order to allow the fitment of the engine in an enclosure to improve thermal comfort, and also fitting the fuel tank outside the driver's cabin in order to allow the fitment of an all-weather full enclosure.
Is that a wing or a grab rail in back?
I wouldn't dare grabbing that. Seems to be a wing.
