Originally Posted by Miller88
I've done my best to try to chart shift points. This engine does NOT like running below 1500RPM under any load. Even cruising, it'll use less fuel at 45MPH in 5th gear than 6th gear.
Odd. You say 5th at 45mph is @1500RPM? Are you sure? Do you know what your AFR and timing are at that? Do you have a ScanGauge? Does this have variable valve timing or fixed?
