Old 01-12-2021, 11:10 AM   #73 (permalink)
Piotrsko
Find the resistor behind the panel for each of the gauges and short it. You will then have fully functioning gauges that displays correct values instead of averaged. Ford got a lot of complaints around then because the gauges were reporting out of tolerance conditions.
You are on your own for the fuel tanks, my 38 gallon single has weird characteristics: 160 miles before it comes off the full bump then drops like a rock to 3/4, then reacts irrationally to 1/2. Below 1/2, it is a reasonable relationship to fuel/mileage. Thank god for the odometer.
