Old 01-13-2021, 11:01 AM   #77 (permalink)
Piotrsko
When I was training for schoolbus the lugging rule was: if it is floored and RPM doesn't increase, it's lugging. Other than that AFAIK there is no other way since they rattle and knock at all speeds. Might be able to tell if you're running an EGT because it will be close to 1300 degrees but EGT on schoolbusses is scary.
