Old 01-14-2021, 06:37 PM   #83 (permalink)
cRiPpLe_rOoStEr
Originally Posted by Isaac Zachary View Post
One time I accidentally dumped the clutch at a stop and quickly stepped on the clutch again. The engine kept running, but as I tried to pull away the bus started backing up. I had changed the rotational direction of the engine and it was now running backwards!
Was it a 2-stroke Detroit Diesel? AFAIK only a 2-stroke engine can rotate to the opposite side quite easily.
