Daewoos were probably the best $1000 new car on the market. Unfortunately they went for significantly more than that.
The best thing about them was the timing sprockets. They had random marks on them that meant nothing. It wasn't until someone was about to reassemble it that they tried to look up "which mark goes where" and found that the correct answer was to mark them yourself before disassembly. And yes, if you were in it because something had broken, you were SOL.
Originally Posted by sheepdog44
Transmission type Efficiency
Manual neutral engine off.100% @∞MPG <----- Fun Fact.
