Old 09-29-2008, 10:51 AM   #40 (permalink)
Xringer
Old Retired R&D Dude
Little Red - '12 Toyota Prius c 2 Two
90 day: 57.82 mpg (US)
"Whitey" Bulger - '14 Toyota RAV4 LE
Originally Posted by achang1 View Post
hmm im curious is it possible to put on a pizza pan thats bigger than the rim? so that it covers part of the tires?
maybe that will help reduce the gap of tire and rim.
That's what I might try to do (if I buy some pizza pans).
Since the center of my rim sticks out about 1/4 inch.
That center area is where I would need to drill my mounting holes
and a flat disc would be floating about 1/4" above the outside edge of the rim.
So, if I could get the rolled edge of the pan to just kiss the rubber a bit,
I think that might be the perfect solution for my wheel..
What do you guys think about leaving the tape under the pizza pan?
Would it help?
The only problem I can think of, is loose tape balling up on one side
and making the wheel off-balance..
Cheers,
Rich
Current ride: 2014 RAV4 LE AWD (24 MPG)
Wife's Pizza Transporter
