Old 01-18-2021, 03:08 PM   #51 (permalink)
freebeard
The depth of an unventilated box cavity for lowest drag was 0.37 * D, where D was 'effective body diameter'.
So that would be a planning parameter rather than a r*le of th*mb.
I don't know what the above depth was, but nowhere near the 560mm I calculate from the above equation (400mm with vents).
Sixteen inches, more or less? Seems like a good candidate for perforating. Did you save the pieces?
Lots of experimental possibilities with slot/hole size and location.
aerohead (01-20-2021)
