Old 01-20-2021, 01:37 PM   #28 (permalink)
aerohead
recommendations
Originally Posted by 01FordCrew View Post
I know the thead was old but thought I'd see who would respond. I would like to upload a picture but I was having trouble getting it to load. I was going to reshape the Box to fit the Bluebird. I've done some preliminary Mockups But want to figure out a parallel link system to keep the top out of the Bus when going through dips. do you have any recommendations on the Best taper? I saw your van Model and was wondering if curving to point or a sharp Kammback cut off was Better
1) I'd have you do a search for US Patent 8590961, by Breidenbach. I has no compound surfaces, would be relatively easy to fabricate, and it's been wind tunnel tested. A delta Cd= 29%.
2) The other is, US Patent 2,737,411, by R.B. Potter, August 21, 1952. It's more organic and 'proper'. It's an inflatable boat-tail. And could be sewn and inflated with a 12-VDC blower. I've tested them. They're very lightweight, take up little space when deflated. Any gear-drive sewing machine would be adequate. Rip-stop Nylon.
