Old 01-21-2021, 10:54 AM   #203 (permalink)
racprops
A ICE engine is at best 30% efferent, that means at best only 30% of the fuel fed into a engine makes WORK, that at best only 30% of the burning fuel is able t push a piston down.
The rest is either still burning on the exhaust stroke, still burning as it leaves the engine which is a major cause of engine heat.
And some just does not burn at all.
This is what the Cats are used to burn this left over unburned gas and other pollutions.
A major fact is liqueur gasoline does not burn. ONLY Vapor does.
The problem is there is not time for the gasoline in a chamber to fully vaporize.
The theory is if gasoline was converted into 100% vapor a engine will run very well on only 30% pure vapor, not needing the 70% not used be a standard engine.
The theory is such an engine would burn nearly 100% of its fuel and thus product hardly any pollution.
The theory is such an engine would get great MPG using only about 30% of the fuel it used to need.
The theory is such an engine will not need any advance timing as vapor burns very fast.
The theory is such an engine will run at a very low temperature as all the fuel is burned within the chamber.
There has been many climes and demos of such systems.
Rich
