Old 01-22-2021, 01:51 PM   #4 (permalink)
AeroMcAeroFace
Long time lurker
AeroMcAeroFace's Avatar
But other than accessory losses, everything else is changing due to the increased engine speed.
I am not saying that a 5% increase in top speed means an exact 10% decrease in drag, there are too many variables at play to say absolutely. The error between measurements is perhaps 10%.
However you can say with absolute certainty that a fixed throttle position will give you a higher top speed if drag is reduced, there is no way you can argue against that.
At least a few mph difference, averaged over multiple readings, it can't all be down to the car suddenly becoming more fuel efficient or is that what you are saying?
The Following User Says Thank You to AeroMcAeroFace For This Useful Post:
aerohead (01-22-2021)
