Old 01-28-2021, 09:27 AM   #26 (permalink)
Piotrsko
AFAIK, alignment is relative to wheel direction. So if all 4 tires are set correctly where the body is pointing (to the tires) is inconsequential. When I had the bug altered to drive straight, the alignment shop had to adjust centerlines of the rear axles for equal distance and change some shims from one side to the other side
MeteorGray (01-28-2021)
