Old 01-30-2021, 10:05 AM   #17 (permalink)
Vman455
Moderator
Vman455's Avatar
Pope Pious the Prius - '13 Toyota Prius Two
90 day: 51.62 mpg (US)
Tycho the Truck - '91 Toyota Pickup DLX 4WD
90 day: 22.22 mpg (US)
5) The fact is, that for half-bodies, the 'template' is the lowest drag form ever measured. If you take exception to that, I recommend that you take it up with those who measured it.
This is an odd statement to make. Scibor-Rylski developed a streamlined body with a contoured underside in the City University of London wind tunnel in the 1970s that came in at cD = 0.07 in ground proximity. It looks very different from the "template." Why shouldn't we all build to that form as a "first approximation"?
10) Only until one has put an 800-hour project behind them, do they realize the benefit of a 'template', as a 'first approximation'.
I disagree. Testing should be the first attack, to find out what is actually going on. I could have spents hours building up the rear glass on my Prius to conform to the "template." It would have been a complete waste of time, since a simple tuft test showed it already had attached flow. So, why not use the 3rd generation Prius profile as a template?
UIUC Aerospace Engineering
www.amateuraerodynamics.com
The Following 4 Users Say Thank You to Vman455 For This Useful Post:
aerohead (02-03-2021), AeroMcAeroFace (01-30-2021), Cd (01-30-2021), MeteorGray (02-20-2021)
