Originally Posted by M_a_t_t
Were you able to get a good throttle stop setup going?
That's going to take some time.
I live in the city, and need to find a road that has minimal traffic, as well as a fast speed limit.
It also needs to be close to where I live, so that I can drive home, and remove aeromods to run tests A-B-A.
There is a good road that is nearby, but the speed limit is 50 mph.
I also have to find the "sweet spot" to have the screw in the wooden block that goes under the throttle.
To find it, I think I will use a piece of soft clay under the gas pedal.
I will have to accelerate exrremely slow to get to the desired top speed,
It might be tricky.
