Originally Posted by AeroMcAeroFace
Seeing as you are obsessed with BSFC, have you considered how much less efficient the motor and controller get at higher speeds and lower loads. It seems like a critical oversight for you to ignore.
After the press have an opportunity to conduct tests on the actual vehicles, we'll have more data to work with.
If you are in possession of bona-fides, then I petition you to release the raw information, from the source.
A BSFC-e motor map would be extremely insightful!
