Old 09-29-2008, 08:34 PM   #43 (permalink)
Xringer
Old Retired R&D Dude
Little Red - '12 Toyota Prius c 2 Two
90 day: 57.82 mpg (US)
"Whitey" Bulger - '14 Toyota RAV4 LE
Originally Posted by rjstegbauer View Post
Cool.
This seems like a simple and effective way to improve FE.
However I've noticed one small gotcha. There is no access to the tire's valve cap, so the wonderful new hub cap will have to be removed just to check the tire pressure. That doesn't seem like a good idea, since they could break if repeatedly removed. Especially if you spend $100 on aftermarket hub caps.
Randy
I've seen a few guys leave off the valve holes with the bolt-on Moon Disc, but if I get some pizza pans, I'm going to try drilling some holes in them and use a valve extender when I top off the 44 PSI..
Cheers,
Rich
Current ride: 2014 RAV4 LE AWD (24 MPG)
Wife's Pizza Transporter
