Old 02-07-2021, 02:37 PM   #149 (permalink)
gumby79
gumby79's Avatar
little jona - '91 Dodge D 250 first gen cummins LE
Team Streamliner
90 day: 23.4 mpg (US)
Little Jona airo modded - '91 Dodge RAM 3/4 TON D 250 2×4 AUTO
Pickups
The Salted Hound Jenny. - '87 Dodge Ram 50/D-50 5sp 4X4
90 day: 20.24 mpg (US)
Jona Allison aero - '91 Dodge Ram D-250 Le
90 day: 20.76 mpg (US)
Cd
Time is not so much a factor in throttle stop testing. Only top speed achieved and MAINTAINED with the Artificially reduced max power.
How long/ min test time. 2-3sec at peak to verify you are truly at max. Just has to be long enough to have multiple data points to average your speed value and confirm max is achieved.
How much is needed?
The higher you set the speed/ throttle stop(TS) for the, test the higher the resalution( smaller things will show better with more speed) .
Smoke in the tunnel is done at ~30-35 mph to prevent thinning the smoke too much to see the evadence. Fuel log records for others with OBD2 port access indacate that commutes under 45mph are less about Cd or A and more about RRC and the nut behind the wheel.
I might suggest setting your TS @
<35 for RRC testing
>45 mph for CdA
2nd peraon?
Using the camera on the 2nd gps phone should work a dandy.
Only issue I see with you using this segment of your commute is installing the TS block enroute. And possibly RRC temperature based discrepancies if this point in your community is not far enough to be at full operating temp for grease and oils.
1st gen cummins 91.5 dodge d250 ,HX35W/12/6 QSV
ehxsost manafulld wrap, Aero Tonto
best tank: distance 649gps mi 24.04 mpg 27.011usg
Best mpg : 31.32mpg 100mi 3.193 USG 5/2/20
Former
'83 GMC S-15 Jimmy 2door 2wd O/D auto 3.73R&P
'79 Chevy K20 4X4 350ci 400hp msd custom th400 /np205. 7.5-new 14mpg modded befor modding was a thing
87' Hyundai Excel
83 ranger w/87 2.9 L FI2wd auto 18mpg on the floor
04 Mitsubishi Gallant 2.4L auto 26mpg
06 Subaru Forrester XT(WRX PACKAGE) MT AWD Turbocharged 18 plying dirty best of 26mpg@70mph
95Chevy Blazer 4x4 auto 14-18mpg
04 Chevy Blazer 4x4 auto 16-22mpg
The Following User Says Thank You to gumby79 For This Useful Post:
Cd (02-07-2021)
