Old 02-08-2021, 11:26 AM   #14 (permalink)
Piotrsko
If you mean you doubt that there is insufficient pressure gradient to flow through the ducts and do something,, then you are probably incorrect. The actual discussion should be will these ducts provide enough flow to stabilize or eliminate the vortex Caused by that fiaring.
