Old 02-17-2021, 01:47 AM   #11 (permalink)
novelinflow
State oftheArt InFlowTech
novelinflow's Avatar
Lightbulb
State of the Art, Novel Tech Space Satellite and Habitat Power-Plant, Generator Self-Feed Unit; H2O=>HHO=>H2O=>HHO 4 Systems All in One Unit
+PLUS; *State of the Art, Novel Technology, Featured Project Development / Space, Satellite and Habitat, Power-Plant, Generator, Self-Feed Unit; H2O=>HHO=>H2O=>HHO=>Etc... *4 Systems All in One Unit, One By One, Plus Four-4 Projects added One to Other; *·1-Gearturbine, ·2-Imploturbocompressor, ·3-Dynamic Generator, ·4-Electrolysis System:
·1-GEARTURBINE; Reaction Turbine, Rotary-Turbo-InFlow Tech,Have the similar basic system of the Aeolipilie Heron Steam Turbine device from Alexandria 10-70 AD * With Retrodynamic = DextroRPM VS LevoInFlow + Ying Yang Way Power Type - Non Waste Looses *8X/Y Thermodynamic CYCLE Way Steps. 4 Turbos, Higher efficient percent. No blade erosion by sand & very low heat target signature Pat:197187IMPI MX Dic1991 Atypical Motor Engine Type.
·2-IMPLOTURBOCOMPRESSOR; Impulse Turbine, Implo-Ducted, One Moving Part System Excellence Design - The InFlow Interaction comes from Macro-Flow and goes to Micro-Flow by Implossion - Only One Compression Step; Inflow, Compression and outflow at one simple circular dynamic motion / New Concept. To see a Imploturbocompressor animation, is possible on a simple way, just to check an Hurricane Satellite view, and is the same implo inflow way nature.
·Note;Plus-this-Two Projects to complete all the System Work/Self-Feed Unit Space Power-Plant-H2O=>HHO.
·3-Dynamic Generator/New Kind.
·4-Electrolysis System/BioDesign.
*(3&4-Hide-Cards-on-the-Hand).
Note: This is the next step.
Featured Project Development - State of the Art Novel InFlow Tech: ·1-Gearturbine: Reaction Turbine, ·Rotary-Turbo, Similar System of the Aeolipile ·Heron Steam Device from 10-70 AD, ·With Retrodynamic = DextroGiro/RPM VS LevoGiro/InFlow, + ·Ying Yang Power Type.·2-Imploturbocompressor: Impulse Turbine, ·Implo-Ducted, One Moving Part System Excellence Design, · InFlow Goes from Macro-Flow to Micro-Flow by Implosion/And Inverse, ·One Compression Step.
Last edited by novelinflow; 02-18-2021 at 10:21 AM.. Reason: just a lil note: key info
