Old 02-17-2021, 09:40 AM   #115 (permalink)
JacobLeSann
The gas tank is about the same height as the cross-beam that holds the two suspension arm pivots. They drop down a bit further than the rest of the underbody. I don’t think I’ll take it out nearly as far as those cars but I’ll see what I can do in the future. The exhaust would be on the right side, but I can modify it if need be. It turns around the gas tank, comes up over the suspension arm, and then juts out the bottom of the bumper. I’ll probably be replacing the fart cannon with a smaller, lower profile custom resonator, so that will help either way.
Is it important that the diffuser carries so far outward of the rear?
