Old 02-18-2021, 02:10 PM   #63 (permalink)
hayden55
Sport Utility Prius - '10 Toyota Prius II
90 day: 52.98 mpg (US)
300k Sequoia 4WD - '01 Toyota Sequoia Limited 4wd
90 day: 20.19 mpg (US)
Originally Posted by EcoCivic View Post
Wow that is a big gain! I doubt that I would see those kind of gains on my D17 though, like I said I didn't see any loss in MPG from swapping in this shorter geared transmission. Also, when cruising around town, I get higher MPG cruising in 3rd gear than 4th gear up until around 3K RPM. The conventional strategy of "cruise at as low of an RPM as you can without lugging the engine" doesn't seem to work for me, perhaps because I have a Crower Stage 1 camshaft. Although it runs well cruising on flat ground down to around 1500 RPM, doing so doesn't seem to be efficient on my setup.
The other issue with the HX trans is those are basically impossible to find here, an 01-05 Civic with a DX/LX/VP 5 speed is hard enough to find here. "Older" Honda's aren't particularly common here and the ones I see in junkyards are almost always autos. Actually I'm not sure that I have even seen a 7th gen Civic HX here
Yeah that cam changes your VE. I always did 1750-2150 RPM to stay in the center island on the map (BSFC Map)
"I feel like the bad decisions come into play when you trade too much of your time for money paying for things you can't really afford."
The Following User Says Thank You to hayden55 For This Useful Post:
EcoCivic (02-18-2021)
