Originally Posted by cRiPpLe_rOoStEr
Now it makes sense. On a sidenote, due to the Coronavirus outbreak, it has been quite common to see Ozone generators being used to sterilize commercial venues. Maybe not too hard to repurpose one and mount it to a truck or bus...
However, Ozone generators are usually of the corona arc discharge type. They suffer from degraded performance if air humidity increases. Producing dry air in large enough quantities is a challenge otherwise the ozone generator delivers highly variable results depending on the weather!
