Old 02-19-2021, 09:09 AM   #117 (permalink)
Piotrsko
With 8 gallon of coolant, you can probably get by without the fan under light load definitely could lose the clutch and run a flex fan Mine only engages pulling a 6% hill on a warm day otherwise the fan clutch is slipping. You'll hear it when it engages, even inside with the A/C on.
The 7.3 is supposed to only burn 1/3 QUART of fuel an hour at idle so theoretical 120 hours on a full tank
