Old 02-20-2021, 04:24 PM   #127 (permalink)
Tahoe_Hybrid
2020 - '08 Chevy Tahoe H
Last 3: 18.4 mpg (US)
2021 - '08 Chevy Tahoe H
90 day: 17.08 mpg (US)
2022 - '08 chevy Tahoe LT
Last 3: 14.38 mpg (US)
2023 - '08 Chevy Tahoe
Last 3: 22.61 mpg (US)
2024 - '08 Chevy Tahoe
90 day: 22.35 mpg (US)
Originally Posted by Isaac Zachary View Post
10-11mg in a diesel sounds depressing seeing how there are a few getting up to 15mpg in V8 gasoline trucks of similar sizes. Not that there wouldn't be an advantage with the 4 banger.
I wonder if it would be advantageous to deactivate certain cylinders in a large diesel. The more the load the more effcient so maybe that would help. ?? I guess it depends on the type of injection system, whether it's a common rail or an injector pump, for an example.
With an injector pump, adding a few extremely high pressure 12V solenoid valves on certain injector lines and then routing that back into the fuel return would do the trick.
There may be problems with the turbo spooling correctly when running on just a few cylinders though. Maybe multiple staged turbos would do the trick. ??
1-4-6-7 (enabled) is what GM uses for AFM
2-3-5-8 are disabled...
