I tried to do some napkin math, but realized I'm technically missing some details. Does that regen of 15-20A have 12v or pack voltage? I'd assume it would be pack voltage, which I don't know. Google says 144V.
20A*144V = 2,880W of power re-generated.
Gallon of gas = 33.7 kW's of power. 33.7 x .4 (efficiency of ICE) = 13,480
So the amount regenerated converted to a gasoline equivalent would be .21 gal
If it is based on the 12v system you can just reduce by a factor of ten and be close. So ~.02 gallons equivalent recovered. So as long as you use less than .02 gallons then I think option 2 would be more efficient.
Does my thought process make sense? That's pretty much how I would consider the problem, so if anyone could double check the math and thought process I'd appreciate it.
1973 Fiat 124 Special
1975 Honda Civic CVCC 4spd
1981 Kawasaki KZ750E
1981 Kawasaki KZ650 CSR
1983 Kawasaki KZ1100-A3
1986 Nissan 300zx Turbo 5 spd
1995 Chevy Astro RWD (current project)
1995 Mercury Tracer
2017 Kawasaki VersysX 300
2022 Corolla Hatchback 6MT
https://www.youtube.com/channel/UC6s...LulDUQ8HMj5VKA
