Old 02-23-2021, 03:20 AM   #3 (permalink)
Stubby79
Stubby79's Avatar
Firefly EV - '98 Pontiac Firefly EV
90 day: 107.65 mpg (US)
Little Boy Blue - '05 Toyota Echo
90 day: 33.35 mpg (US)
BlueZ - '19 Nissan 370Z Sport
90 day: 17.19 mpg (US)
Originally Posted by M_a_t_t View Post
20A*144V = 2,880W of power re-generated.
Gallon of gas = 33.7 kW's of power. 33.7 x .4 (efficiency of ICE) = 13,480
Need to equate time in to your calculations. The gallon of gas is already in kWh.
10s = 0.002777778 of an hour, so 0.00277778*2880 = 8Wh = 0.008kWh.
8Wh isn't insignificant, about the power of a single 18650. It's not a lot either.
OP: The only gas you would be using is the initial blip to rev up the engine, after that it would be in FCO until you get down to 1500rpm. To maximize the time between and the power generated, you could go for a lower gear, or shift again. Regen seems to stop about the same time as FCO cuts out.
You could continue the math...my Geo Metro used about 0.15 GPH to idle. Buuuuut....since its just the blip and the last moments when you get down below 1500rpm, I'd say it's negligible. Negligible vs "not insignificant".
When I got my IMA system working, at last, my gas mileage got worse at first because of all the times it wanted to go in to regen when I'd normally not-quite-coast in gear (the engine drag is very minor in higher gears)...I had to retrain myself to hold the throttle ever-so-slightly open(Keeping it >150mpg) unless I wanted to shift in to neutral (at which point I would pick up too much speed). Was rather annoying.
Point of that story is that regen does not make up enough for the losses along the way, so I generally only let it regen in place of braking, and since it doesn't get a lot of that, I try to make sure I use it every reasonable opportunity, so the engine doesn't have to "refill" the battery pack while driving. So far so good...it's almost always nearly full; I've only once had it get down to half where it forcibly starts charging while driving.
So, yes...I'd say it's worth it any time you're going to forcibly slow down for more than a couple of seconds.
The Following 2 Users Say Thank You to Stubby79 For This Useful Post:
M_a_t_t (02-23-2021), Natalya (05-09-2021)
