Old 02-23-2021, 04:35 PM   #4 (permalink)
IamIan
IamIan's Avatar
Originally Posted by Natalya View Post
Note:
The Insight restarts the ICE with the IMA motor, but I HAVE to hit the gas pedal as well or else I'll wreck my transmission. I usually choose third gear. I might need to get up to 3000 RPM or so to match the engine so I can safely release the clutch.
One other option .. You could also combine FAS with IMA motor (MIMA or IMA-C&C) to rev up the ICE , without using any gasoline for the power/energy to do the ICE reving .. keeping zero gasoline flow the entire rev-up time .. once at desired RPM and in desired gear enter regen as desired.
Life Long Energy Efficiency Enthusiast
2000 Honda Insight - LiFePO4 PHEV - Solar
2020 Inmotion V11 PEV ~30miles/kwh
The Following User Says Thank You to IamIan For This Useful Post:
Natalya (05-09-2021)
