My dated SAE Handbook recommended :
* 16-degree approach
* 10-degree breakover
* 10-degree departure
If you 'slide' any of these angles along the ground plane until they contact the tire face, and they strike any part of the body when loaded to SAE test weight, you run the risk of a ground strike in daily operation.
Active air suspension can easily mitigate these issues. Best of both worlds.
