Wrong thread?
-samwichse probably wants to draw attention to ejectors used at the back of that Tatra 603. While I do not object that ejectors can produce massive amount of moving air, I have conserns about total momentum (and thus generated thrust). Will look into it for sure. Good point!
- I don't understand why they retract. If not, they may augment that slotted wing.
- I commented on the front wing at #3, but it was neutral just to draw attention to it.
- The flying scale model has a reasonable round-ended rectangle duct, the investor friendly rendering has an odd kink in the bottom.
But they do have a flying scale model. Maybe they know what their doing? Productizing it is an whole another matter.
- i haven´t noteced this. kinda hard to read comments carefully at 2 o clock in the morning.
I too wish it became a true, But Mollers Skycar, Aptera, Elio, Nikola Motors....
Both Coanda and Bernoulli were tested for transportation (either rotary wings, or rotary sails, or to improve STOL performace) and usually utilized only in special (military) applications, where efficiency is not the main concern.
I Will watch their progress though. You found interesting project.
